clip and wires, do they relate?
Really the wrong way to look at it...you should be concerned about the input voltage, not the 12VDC side of things.
If you have the wire sized too small, ideally your fuse will blow before the amp has a chance to reach rated power. If you don't have your gains set correctly, it still may clip at a lower power level.
well i have 4gauge wire that divides to 2 8gauge for 2amplifier...
i thought of getting a distributor which will be all 4gauge, would i hear a difference or its money wasted?
i see 8gauge can transfer 50-65amp
4gauge can up to 120amp
http://www.partsexpress.com/resources/cablecalc.html
and my amplifier is 120amp(30x4)
so i have a feeling that im not using my amplifier's full potential?
am i correct...?
How long is the run of 8awg?
If it's only for a foot or so, that shouldn't make a difference in current handling. Now, if you have it coiled up everywhere, that's a problem //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
1 8gauge is about 1feet long and the other one is about 3foot(my other amplifier is 60amp...
alright so its not necessary to change to 4gauge right?
Is 120 amps the total of the fuses on your amp, or what is it's continuous amp draw? One of my amps has 2 30 amp fuses for a total of 60amps but only draws 33.4 amps max... 8 gauge should be fine.
SQBubble
SQBubble
MTL
Hydrastas
Mike Mccabe
