Classes of Amplifiers
It has to do with how the circuitry is designed. But for car audio purposes, efficiency is the most important element, because we have a limited amount of power capabilities in our vehicles.
Class A and A/B amps are usually in the 50-60% efficiency range and class D hover around 65-85%.
I don't have facts in front of me to back this up, but Class D tends to be around the same efficiency as Class AB until the output ramps up toward clipping. They get more efficient as the duty cycle increases. Regardless, I recommend Class D full range amplifiers for customers who don't have a preference as they're typically smaller and more powerful than a comparably priced Class AB amplifier.
really starting to wonder when i see these d/f class amps and up like class h i think i seen....
You're correct. It's not unlike the efficiency of a cordless drill running at full tilt or attenuated. When the volume is turned down or when the trigger on a tool is only pulled part way in, the attenuation of that voltage creates, necessarily, some loss.
But then, amplifier efficiency is also affected by impedance, so with lower impedance loads, efficiency goes down and since most amp manufacturer's (if they do at all) rate efficiency at 4Ω, even though most bassheads run at 2Ω or lower... maximum efficiency is almost never seen.
And that is just one more reason why we need overkill on the supply side of the equation.
I believe a class A/B is much less efficient at low power levels as well. It's something about the switching of the power supply that makes the class D more efficient.. Maybe someone else can go in to more detail.
Class D does get much more efficient as the output approaches maximum... as does class A (though class A isn't really terribly efficient at any time)
All just variations on PWM (Class D).
The old Zed manual had a good breakdown of types of amplifiers.
It's been a good while since I've read it. It's got a ton of information, and I'd recommend anyone wanting to learn more about amplifiers to read it.
Each year covers different facts, so don't be afraid to go in and read the 2010, 11, and 12 manuals. I'll try to remember to upload the 2013 manual on MAF tonight when I get home. TONS of good info in there.
Whiney
Whiney
Ga
neo_styles
