Class D vs Class AB wattage
MDDrew
assuming i have set me gains correctly, if i put my volume from my head unit and the same place will i get the same volum also assuming both amps are rated the same..
Blaupunkt va4100 vs Kenwood KAC X4R running in 3 channel mode 2 comps + sub
just want to get that clarified since i heard class d is more efficient, not worrying bout the ele. system just wanna know if i will get same power.
I don't quite get what you're asking //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Getting the same power depends upon what load the amps see from the speakers too.
If the amps are rated the same and you have the gains set the same, then you will get the same power output.
The class D is more effcient, so it takes less power in to make the same output power as a class AB.
no. no 2 amps are exactly the same, even if they are the same model number. moreso, if they are both from different manufactures.
i just wanted to make sure output was the same and that class d just strains ele. system less
ill be using to comps + sub 4 ohjm svc
MDDrew
MDDrew
N.O.
MDDrew
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
