Class D vs. class a/b Amplifiers
Jleff8621
I am trying to decide which one i should get. i would be hooking it up to two spr-50c speakers. Right now i have them hooked to the HU but its just not enough. Without an amp my two sub just over power them. When the subs hit i cant even hear them. So im fine on bass but i want nice loud highs and mids that i can hear when the subs hit. So which amp would be ideal for this? And whyy?
^^^This. Class D is gentler on your electrical than A/B and normally comes in a smaller profile. For just powering your comps, either one will work fine.
If money isn't an issue buy a good full range class D, there is no downside. If you're thinking of buying a budget priced full range class D I suspect you'd regret it. The ones that are worth owning are not cheap.
They "say" that Class A/B have better SQ because there's always a current going through it and other crap like that... But there's really no proof to back it up. I think it's another one of those things like capacitors - pretty much useless.
Anyway back on subject, a class D will usually be at least 20% more efficient, but either class of amps will work well.
So theres really no difference between the twoo? And id be getting the Alpine MRX-F65. Is that a good amp? I mean i dont think you can go wrong with alpine but i just want to make sureeee.
d class full range amps are known to have high distortion but how do the manufacturers reduce it' date=' I don't know.......[/quote']
cheap class D amps*
This is mainly because class D have been 'traditionally' used as sub amps and anything below about 10% distortion isn't too noticeable
They use whats called "a brick wall filter" that removes most of the switching noise above 20khz that class D makes.
In component amps you wont be saving much amperage draw versus using an A/B amp anyway, so if you are building for SQ use an A/B if its within your budget.
i think amps sound different because of slew rate, not just THD. a well made Class D will be just fine. Efficiency comes with how long the transistors are "on". traditional class A/B allows some overlap so half of the amp is still on when not being used - the result is much less distortion over Class B but lower power consumption (better efficiency) compared to Class A. As mentioned, modern Class D (and similar hybrids) switch much faster, have proper filtering, and are just fine. but many people prefer an amp topology that doesn't require filters to remove the nasty side-effects.
for speakers, power is low anyway and efficiency isn't much of a concern. class A/B is fairly cheap, especially used.
It should be good. MRX amps are some of the best budget amplifiers. I'd recommend either this or PPI Phantom P900.4. My only concern with Class A/B amplifiers is that if I drive my midbass speakers and play music loud, they can run stupid hot during Texan summers, so they're a bit more sensitive to where you place them. On the other hand, Class A/B amps have gotten much cheaper these days. Consider the PPI bk800.4. It's power output is close to P900.4, but it costs a bit less (and 1.5x as long in length..)
Jleff8621
Jleff8621
Richmond,Va.
n2audio
vegang
vegang
