class d questions
well right now ive got my amp run mono at 4 ohms with 600 whats go 2 a single M1 15 n it supposed 2 be 500 max n i dont know if my current amp is 2ohm stable how could i figure out if it is
The xta600.2?
Each channel is stable at 2 ohms, but when bridged it's only stable down to 4 ohms.
Amps come in different classes based on their quality / efficiency.
Class D are usually used as subwoofer amps since they have relatively low quality, but are somewhat efficient... thus getting more "bang" for your buck.
There are many classes, ranging from I think A to D, including A, AB, B, BC [i think], D.
At least, this is what I read on JBL's website or something like that.
The amp works by bringing in power and AMPLIFYING it... this works with physics and a whole bunch of coily-things.
At any rate...
If you plug subs into any amp, it'll distribute the current evenly... but, this isn't as simple as it might appear. You have to compute in impedance. Check the link that brt posted. Make sure that you're doing it correctly. Don't wanna blow your amp / subs.
And always remember to set your gains CORRECTLY the first time.
Wow you are an idiot.
nG
memphisman
SLASH N' BURN
memphisman
Gainesboro TN
ngsm13
