Clarion subs
My buddy has 2 Clarion pxw1051s, and wants me to make a ported box. The manual lists a 3 inch round port whether running 1 or 2 subs. The single configuration lists the port tune at 35.5hz and the double setup lists 31.1hz. My question is why is the port so small for 2 subs. The xmax is 12mm and sd is 330sq cm, as a pair I would think they'll move more air that a tiny 3" port could handle. Thoughts?
i use a 4 inch port per cube and a half, if your're slot porting its around 15 square inches of port per cube.
and as far as not being able to move the air the 3 inch will move the air just at a higher velocity causing you to hear horrible port noise
for 1 they list 1.0 net and a 2.5inch round 11 1/8 length with f3 of 31.02 hz.
there is a single spl setup thats 1.0 with 3 inch round port at 7 3/4 long f3 is 35.5hz.
the double setup they list is 2.0 with a 3inch round port 6 7/8 long f3 is 31.12hz
THATpurpleKUSH
Fuckyou
THATpurpleKUSH
Slums of the Shaolin
RAM_Designs
