Clarion PU-9317A Wiring Help
banzia
uk
Hi From Scotland,
I was hoping you could help. I have the Clarion PU-9317A and I wish to fit to an older type car, This means that I will have to remove the wiring plugs at the rear of the unit and connect using baynet type connections.
My problem is that I dont know the wiring codes for the clarion unit and was hoping you could give me some help with the wiring setup.
There are two sets of wires at the rear, one set is for speakers and I can work them out but, the 2nd set is the problem. I will list the colours and hopefuly you will know the function..
1 X Black Wire
! X Red Wire
1 X Blue Wire
1 X Blue Wire with White Stripe
1 X Yellow Wire
Thats it my freind, it took me a very long time to find you so please help....
Regards
James
Glasgow, Scotland
1 X Black Wire
! X Red Wire
1 X Blue Wire
1 X Yellow Wire
The black wire is the ground wire.
the red is your 12v constant power
the blue is your power antenna
the blue w/ white stripe is the amplifier turn on.
the yellow is the acc power wire.
banzia
banzia
uk
johnecon2001
