Clarion cz702 amp guard
  • 4
bmk6795
Ok I'm having an issue with my cz702. When you turn the volume up past 32 ish after a couple minutes the volume is then replaced with "amp guard". All the research I've done indicates a short in one of the speaker wires running to the hu's internal amp, however, I'm not using the internal amp. anyone have any ideas?
I had this issue when using my internal amp, but you say you are not using it all?
Are you sure you did not leave any stock wiring connected to the headunit?
Nah none of the speaker wires are used on the hu. Only have a singe comp set up front and they use the passive crossovers.
---------- Post added at 12:44 PM ---------- Previous post was at 12:44 PM ----------
Did you turn off the internal amp?
I did not but I will and see what happens. Didn't know you could turn it off.
I think that was the problem. It was turned off, and the instruction manual said it needs to be on. Thanks man.
Yup kinda confusing to have the internal amp running you neet to put it on "off" but to have it off you need to put it on "on" lol
Np!
It happens to my friend's unit too. It is sensitive to clipping down to the recording quality of the music files. If it thinks the output signal is too strong it will shut off to reduce harm to speakers.
Or it could be a bug and something's wrong with the unit. Disconnect all RCA and speaker connections, turn it up all the way. If it still displays the message, you need to turn it in for RMA, if its not then its just the music recording.
Some music from decaf, you can easily go up to 40 on the volume and it will not display, some will start displaying at 32, 35 etc depending on the gain built in the recording of the song.
Now that we are on this HU do any of you guys know how to add more trebble? Im in mormal mode and have NO clue how to mess with the eq, the mids put play the tweeters and i dont like it
When you are in the adjust eq settings set it to custom then turn up the G and F settings till you like it best. The Q setting is mids.
If not just do it all thru the amp of possible.
Looks similar to this: https://www.sonicelectronix.com/item-17681-Clarion-CX609.html I'd call Sonic Electronics and see if they have what you...
Thats its manual fore using, not Tecnical.expaining , have pinted out service manual., and the cable i think was fore swc,its made fore satelite...
I dont think anyone can answer that question of if a BTooth adapter will sound as good as a CD? Only one would know by actually using the same...
922
I would recommend to get on F.Book @ Old School Stereo and run a Want To Buy thread there. Im sure someone is hoarding one, maybe even a BNIB one...
I know what you mean ....its a pain going in all those menus ...i think kinda look at these new decks like old school trunk mount processors...
bmk6795
bmk6795
Spartanburg, SC
los33
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
