clamping amp
splwj47
i was trying to clamp my amp to see what kind of power it actually puts out at 1 ohm since its not 1 ohm stable but when i do the test with a 50 hz test tone my voltage is right at 24.4 but the amps only goes to 5.5 amps and thats only like 125 rms i have the multimeter set to ac volts and the clamp set to ac amps i dont know what im doing wrong
24.4VAC with the subs connected? what is the fs of the subs? near the fs the impedance spike will greatly reduce current. try other tones, like 100Hz (assuming your meters can measure AC at frequencies other than 60Hz - check the manual).
splwj47
splwj47
Great White North
vector
michigan born
    May 14, 2026
michigan born
    May 14, 2026
