Circuit breaker blowing
Its a hifonics 2006bd. I have an orion 15h2 running at 1 ohm. I have 0 guage running from the battery to the cap. Its a boss 2 farad cap. From the cap I have a 4 guage ground and 4 guage running from the cap to the amp. I don't have any electrical upgradesbut I thinking i'd need the big three and a ho alternator. What size circuit breaker do you think I should be running. Thank you
Your ground is WAY to small... You need to use the same size ground as power, in this case: 0 ga. Check your ground connection as well, make sure you got bare metal ... Circuit breaker? You mean fuse? Look at the wire chart for 0 ga. fuse size...
K I thought the ground size didnt matter. Thanks and the ground isnt fully touching bare metal. The circuit breaker I got blows and you just push a bar inside and its fixed again. The man at the car audio shop said itd be cheaper than buying a fuse and replacing it everytime it blows
Its actually more important to have a proper sized ground wire than power. The guy at the shop is a jackass, replacing a fuse holder with a breaker isn't a solution.
andrewbny2002
andrewbny2002
New York
ultimate157
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
