Chevy Headunit Color Code??
SHiZNiLTi
My 2001 Chevy 2dr Blazer has 6 speakers....
4X6" top of dash
6.5" front doors
6x9" rear panels
Everywhere I look on the net I'm unable to find the correct wiring diagram which displays all (6) speaker wire colors.
Does anyone know the colors for all (6) speakers?
Here is all that I've found...
Radio 12v orange + radio harness
Radio Ground black - radio harness
Radio Ignition dk. green + radio harness
Radio Illumination brown + radio harness
Factory Amp Turn-on orange + radio harness
Notes: The amplifier is behind the glove box.
Power Antenna N/A
LF Speaker +/- tan - gray +,- radio harness
RF Speaker +/- lt. green - dk. green +,- radio harness
LR Speaker +/- brown - yellow +,- radio harness
RR Speaker +/- dk. blue - lt. blue +,- radio harness
Thanks!
Use process of elimination from the diagram you have. Whats left over could be the set of wires you are looking for. IDK, might work. and instead of cutting your wires to use the 9V bat. method, Use a pin and some wire with alligator clips in the end.
Good ideas. Im checking it out tonight. Im sure the 9v battery to the pin in the harness will work if I use some alligator crimps which I happen to have a few sets laying around.
SHiZNiLTi
SHiZNiLTi
Scottsdale, AZ
SHiZNiLTi
