Checking impedance with a multimeter.
Dtrom
MAF
Not even sure how to word this...
How far away from the original coil impedance means the coil is still good?
If I check the coil on a D2, what range of numbers on the meter will show that the coil is still in good shape?
well figure how much the meter is off also, then take a measurement and minus that for an estimate.
Are the meters always off by a lil bit?
---------- Post added at 03:58 PM ---------- Previous post was at 03:57 PM ----------
in my testing usually they read about 1.4-2.6
What would a bad coil read, roughly?
Coils don't usually short or change resistance. When they burn they cause the cone to bind and you can feel it when moving it with your fingers. An open coil will be obvious on the meter. Applying a tolerance to the reading doesn't mean much.
You cannot read impedance with a multimeter, you can however read DC resistance. DC resistance will always be off of what the actual impedance is, usually a few .10's.
Aka D2's will actually read somewhere around 1.7 depending on atmospheric pressure, temp, etc. D1's will read somewhere between .7 and 1 ohms.
Dtrom
MAF
Dtrom
Flex68
