I have my lpf set to about 80hz, I dont set it higher cause I don't like the higher bass notes. Subsonic is about 40hz, thats about where my box is tuned to. I'll play with the 2 and see where it gets me on speaker output voltage, thanks for the advise. About gain, my understanding. Is to set it to the hu so your amp doesn't start sending a clipping signal. I know the max speaker output volts would be the highest I would want to set the gain by checking with a dmm. An oscope is suppose to be the best way to set cause you can actually see at what point the amps starts clipping. Now, my hu says 2v max to the outputs. But thats with all levels turned up, I could barely reach half vol without distorting the highs and mids. So would it be beneficial to get a line driver to set out put volts to amp higher and not have hu levels so high? Would it help me get max volt output from amp with out having to turn gain up so high? I should of commented earlier that when my hu levels are all at max my amp output volts can reach 28.28, but the hu amp is distorting highs and mids way early in vol. Line driver? It sounds good how I have it set now, but only getting 20v on amp output. That only equates to 200watts. I paid for 400watts, I want to use all of it. Plus my sub is rated 200rms to 600rms watts.
