cheap subs
Originally posted by Jeremy jl fan alaxan your so stupid just shut the **** up I dont steal shit you can ask some peepz im doing deal right now for subs and amps. Yea you can get the 1200q for 100$ at CarDiscountStereos
I have been doing this for 12years. I have studied and learned a LOT! I am still studying and learning! I do sometimes give incorrect or bad advice, however I make it a point to step up and appologize or correct myself for what was said. You running around here spouting off lies and bullshit is nothing more to me and many others than just that......BULLSHIT!!!!
**Waders are on now so I can walk eaiser in all the shit you have been spreading around the forum here**
**Flask/baton is prepped too**
Originally posted by infinifosgate would it make that big of a difference if i bought 2 ten inch audiobahns compared to the twelves?
If all you are looking for is spl with little to no SQ go for the audiobahns..... and no it will not make much difference aside from you will lose a bit of sound pressure due to lask of air space movement.
Originally posted by infinifosgate alright, thanks, uhh....if i went with the audiobahns...a little advice on what I should set the gains at?
Turn the gains all the way down and turn your stereo all the way up to the highest you would listen to.... then turn it up one or two notches more......now slowly bring the gain up until you hear a slight amount of distortion......then bring it back down until it is clear and perhaps another notch or so down would not hurt. Now your gains will be properly or should be properly set.
Originally posted by Alaxan I have been doing this for 12years. I have studied and learned a LOT! I am still studying and learning! I do sometimes give incorrect or bad advice, however I make it a point to step up and appologize or correct myself for what was said. You running around here spouting off lies and bullshit is nothing more to me and many others than just that......BULLSHIT!!!!
here alaxan this should help your case
infinifosgate
infinifosgate
wisconsin
Alaxan
