is this big enough?
thegunner
XXX = Audio ***
i figured out how to fit 5 cuft into my trunk and can put a 15 in it. i am gonna get an e15k should i get the e15kd4 or d2? are they 300 watts rms per voice coil?
will this sub work good for spl in 5 cuft?
what should i tune it to?
how much bigger would the box seem with poly fill and where can i get some
I really appreciate your help
Originally posted by thegunner i figured out how to fit 5 cuft into my trunk and can put a 15 in it. i am gonna get an e15k should i get the e15kd4 or d2? are they 300 watts rms per voice coil?
the coil setup should be based on what amp you have for it.
eric
Originally posted by thegunner i have a crunch amp that is 4 ohm stable in mono. i dont have the money to buy a new amp so it will have to do.
well, it sounds like you need a d2 then. then later on, you could add a 2nd and a jbl 1200.1 or something that makes TONS of power into 2 ohm mono, and youll be set.
eric
thegunner
XXX = Audio ***
thegunner
Bozeman, MT
nismo
