Cheap dremel set
_DjScrew_
Dremel Duo Kit 7.2v 2-Tool Kit with Stylus and Driver
$59.99 + $5 shipping
http://www.woot.com/
* Powerful 7.2V motor, for a wide range of screw driving applications. Can drive up to 3” screws* Compact, lightweight, and under 5” in length. Gets in tight spaces others can’t
* Rechargeable 7.2V Lithium-ion battery holds a single charge up to 2 years. Recharge any time with out memory effects
* Ergonomically-optimized grip with T-Handle design for balanced comfort and control
* Precision variable speed trigger with reverse, for superior control when starting, driving and removing fasteners
* Motor brake, provides control and reduces screw stripping
* Automatic collet lock, for hand tightening when needed
* High powered, rare earth magnetic bit holder; can hold standard 1/4” hex shank bits securely
In the box:
* Dremel Cordless Stylus* Dremel Cordless Driver
* Screwdriver bit storage
* Tool Storage Bay
* Accessory Case with Polishing, Engraving, and Sanding Bits
_DjScrew_
_DjScrew_
omaha, nebraska
SyKo13
