Cheap DD Replicas
all install dependent, i thought a mod would know this //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
//content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
Wait...I'm confused....
Does FI have a website?
How's the SQ:confused:
Sucks //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Good news is... I tested an SAX-100.2 on them at first and it was pretty ****ed loud. No metering as it is in my workshop, not in a vehicle.
I used an entire tube of epoxy on the spider landing... so we'll see how it holds up now. I've got to go buy more epoxy to "pre-fix" the other one -- I think I have a solution.
Got mine today and did some testing on the 12. The enclosure was a 2.5ft^3 @ 35hz. It was powered off a sundown 1500d @ .5 seeing ~ 1800rms. Was doing very well and running strong for about 10 minutes then i ran into the problem jacob mentioned. The spiders seperated from the landing on the basket. It slightly folded the cone also after it let loose. Im going to get some coil messurements now. Also i have two 15's still, im going to re-enforce the joint with some ca glue b4 i realy hammer on them.
Corey
Okay... more news.
The good:
* Laying down an entire tube of epoxy around the perimeter of the spider landing does seem to keep it attached. I put down epoxy all around the perimeter AND added more on top of the top spider.
* Tested @ 1400 watts measured free-air in my lap @ 50 Hz for about 10 minutes... no spider landing failure with the "pre-fixed" woofer (not the one that I fixed after I blew the landing).
The bad:
* Discovered a serious design flaw with the spiders. The bottom set of spiders are not set up correctly, likely they should be faced the opposite direction (mirrored). Saw this same flaw w/ the 15s my customer brought by -- thought it was a triple joint failure due to the noise it made.
* The problem is actually that the inner roll on the bottom spider will invert itself on rearward stroke and it sounds like the sub is blown or badly damaged.
* The sound it makes is quite loud and noticeable due to how stiff the spider is.
So... looks like they may be fairly promising for SPL after all with some seriously amounts of epoxy applied to them. But, the spider inversion problem would render them totally unlistenable for me... at least at high volume levels when the woofer reached over ~12-15mm of x-max and the roll inverts itself.
I will be testing the more long-term as "dummy loads" on my test bench... will be using them to power test amps before shipment.
Konaki Motor
Konaki 10?
Corey
So they do NOT have the pole channels like DD, eh ?
So... two differences from the 9500G motor. No horizontal top plate channels and not vertical pole channels. This means that the 9500G will still handle more power due to the added cooling.
sundownz
Pro Seller
Supporting Vendor
sundownz
North Carolina
Cameron_B
