Wire it intertwined through your rims, and wrap directly around your engine block then ground it to your chassis. For more risk of moving parts and heat, mount it to your alternator bracket!
Not a good idea. You need to be extremely careful of heat (or wrap the wire in a heat resistant cover perhaps...) and moving parts anywhere nearby. Be wary of alternators, belts, exhaust, transmission, and the like. Your best bet is to keep looking. Nothing in those two pictures looks spectacular... I can take a look at a friend of mine's 01 mustang and give you some ideas perhaps.
Well I was planning, to be completely honest, on finding the stock ground bolt. If you for some reason dont want to use that, Ill look into it for you.thanks. would really appreciate it if you could help me out. a snap shot would help.
Check it with a dmm to make sure it's a good ground first.waht about this...same thing no?
than find one... Any bolt onto the block will do. Make sure the terminal is touching the block directly, and not bolted onto something else that is bolted onto the engine block, like your original pic of the alternator.^^there is none
What should it read with DMM?Check it with a dmm to make sure it's a good ground first.
