Chassis To Engine question
^^ rule of thumb. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif well thats what I did anyhow
Wire it intertwined through your rims, and wrap directly around your engine block then ground it to your chassis. For more risk of moving parts and heat, mount it to your alternator bracket!
Not a good idea. You need to be extremely careful of heat (or wrap the wire in a heat resistant cover perhaps...) and moving parts anywhere nearby. Be wary of alternators, belts, exhaust, transmission, and the like. Your best bet is to keep looking. Nothing in those two pictures looks spectacular... I can take a look at a friend of mine's 01 mustang and give you some ideas perhaps.
thanks. would really appreciate it if you could help me out. a snap shot would help.
Well I was planning, to be completely honest, on finding the stock ground bolt. If you for some reason dont want to use that, Ill look into it for you.
waht about this...same thing no?
^^there is none
than find one... Any bolt onto the block will do. Make sure the terminal is touching the block directly, and not bolted onto something else that is bolted onto the engine block, like your original pic of the alternator.
ohms. the idea is to find a spot on the engine block that has very little resistance to the alternator casing which is the main ground for your car. at least i think that's what they're referring to. =)
Hello!I'm in France and I can't register on Hifiengine for unknown reasons and i need to download the service manuals for Blaupunkt Baden Baden...
Then I don't really seen the need to run a ground directly from the alt, but given your situation, it can't hurt.
24
3K
I would run another ground wire to cleaned off metal. Sometimes there is a Metal Bracket under the dash that generally work well. You can try...
Sounds like a ground loop, especially with the hokey ground. I'd ground to the body, do the big three. Run a ground from the radio to the amp's...
Nice looking RCAs. Most vehicles these days have quite a bit of wiring to go back to the vehicle lighting ect that run along the bottom door...
15
juan310
juan310
Los Angeles, CA
questionaire
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
Latest topics
