Charging Battery Bank
Bostonjlguy
I want to build an amp rack that will enclose the battery bank so you cannot see the batteries. I have an optima yellow top under the hood and 2 vmax charge tanks ct3500's in the back. The batteries are ran in paralell. Can I charge the charge tanks by hooking a charger up to the yellow top up front?
Not good for introducing new guys to lithium Lots of burned down cars from user error because the tech is new and people are ignorant.
24
Toyota is really efficient. Usually the life of a Toyota last 18 - 25 years before the car or truck begins to wear down. 25 years then fixing...
16
14.6 is max charge for headway. 3.65 volts per cell. There should not be any voltage drop from your alternator wiring to battery so 14.8 is too high.
How often are you charging? I charged mine once when I built it over a year ago and maybe a couple times while I had the car pulled apart. I...
For the pt cruiser, neons, and other pcm controlled charging systems these parameters need to be altered with tuning software. The two tuners I...
Bostonjlguy
Bostonjlguy
Dubuque, IA
mylows10
    May 12, 2024
Brendon Jenness
    May 11, 2024
