Changed setup from 8 ohms to 4 ohms
The t/s parameters probably changed a bunch going from one coil on each sub to two...I'm surprised you can even tell that you're running the same subs.
Are they supposed to go alot louder since the change?
//content.invisioncic.com/y282845/emoticons/omg.gif.05aa02c3095d6ce9338996654eca0863.gif
//content.invisioncic.com/y282845/emoticons/hilarious.gif.02a037aad04aa96f19982b298a3d70a8.gif
Im a little confused about how it was wired before, but if you were only running 1 coil off of each sub, and it was in parallel and not series, your amp would be seeing 2 ohms not 8 which would explain why there is not much of a difference in volume. kinda tired so math is not working so good right now.
thedj
thedj
UK London
metallicaddict
