Change my Battery and now have LOUD Alt. Whine.
bobo244
Basically what the title says. I changed my main battery under the hood and now I have I terrible alt noise. I have the big 3 done and a second batt in the back.
I replaced the battery and turned the car on and my speakers and subs made extremely loud terrible death noises so I turned off the radio turned around and saw smoke coming out of my sub amp. Wasn't very happy. I unplugged the remote wire for the sub amp and the 2 rear RCA's to the 4 ch. And now the front two speakers play music but have terribly loud alt whine.
Looked under the hood and everything seems fine. From the (+) side on the batter there is a wire going to the (+) post of the alt, another going back to the second battery, and the third is the stock GM wire that feeds the car. From the (-) neg post there is a wire straight to the ground, a wire to the alt's grounding post, and the GM negative wire. (200A HO alt)
Before I changed the battery I had an isolator inline with the wire back to the back, and took it out when I changed the battery because I never used it, that is the ONLY thing that is different. Didn't touch anything NOT under the hood.
It looks like the sub amp is blown, when I hook it up it the red LED comes on and it doesn't power up.
So I want to fix the 4 ch so I have something to listen to then work on the sum amp.
ANY IDEAS???
you shorted out your RCA? a Pioneer specialty which is the reason I hate Pioneer........
You should have disconnected both batts before doin the swap,thats all I can think of
I am betting you still had the secondary bat hooked up while you did your swap
and it sent a spike though your system
The RCA's didn't short out because it still works, music still plays but there is a loud alt whine.
I replaced the batt under the hood with a standard battery, the batt in the back is an Optima.
I disconnected the positive lead of the battery in the back when I changed them.
I also tried to reconnect the terminals on the negative side of the batt and they look snug.
Any other thoughts of what could introduce such a loud alt whine????
If you’re logged in the word censor is now turned off. Happy Holidays everyone!
718
This type of controller will work on any amplifier (or specific channel) as it is inline with the RCA connections and functions entirely as volume...
926
Man.. thats nice you guys got that one figured out. Sweet. Ill have to remember this
It may be the sizing of the images.on my ddx396,thats what it came down to.the sizing.said the same thing as yours.unsupported files.took me a...
bobo244
bobo244
Miami Florida
ThatChevyGuy
    May 18, 2024
    May 18, 2024
