Center channel help
Jimg
CarAudio.com Regular
What is the best way to set up a center channel?
I am doing a complete stereo overhaul in a 2016 tundra
So far what I have equipment wise
head Unit. jvc. Z1000 w
subs behind rear seat two 8 inch Rockford fosgate p2
Door speakers 6 1/2 SB acoustics SB17
Tweeters massive ct2 I will put them in the dash or sail panel, what ever works best
amplifier 1 One 4 channel
amplifier 2. Mono amp for the subs
I was planning on just using a 2 way active setup up front and using the features of the JVC
is it worth the added cost to add a center channel?
there is a place for a center channel in the dash on the 2016 Toyota Tundra
would it be worth adding additional amplifier and a center channel speaker?
Would only be adding a 3 1/2 speaker in there.
if yes what additional equipment would be needed?
What dsp works for adding a center channel, will a Dayton dsp 408 do this?
what low power amplifier would work best
To me that's a lot of work and a lot of money for very little reward
I do suggest getting the Dayton either way and using that to run active rather than the HU
6.5 comps and 2 8's in a truck should sound just find
Jimg
Jimg
Kickstand
