CDT HD-1 + CS256 Center/Rear Channel or Fill Setup
  • 2
wanderer1
Laughlin
Item(s) for Sale: CDT HD-1 + CS256 Center/Rear Channel or Fill Setup
Item(s) Description/Condition: Housed in a new black anodized aluminum bezel with a special designed wide dispersion front horn housing. Wide dispersion never heard of before in a silk dome top high energy/smooth performance tweeter.
The HD-1/BL silk dome tweeter driver is very airy with the smoothest power response. The silk dome is super sweet and forgiving. Your smile will stay on forever. Super power handling to match any high-end high powered installation.
HD-1/BL is designed around a neodymium ferro-fluid cooled magnet structure. Frequency response 1500Hz - 21.000Hz. Impedance 4Ohm. Power handling 170Watt or even more when used with CDT designed crossovers. 1.1" Silk wide dispersion dome tweeter ferro fluid cooling
•Neo charged magnet structure
•Frequency response: 1500Hz-21,000Hz
•Impedance: 4 ohms
•Sensitivity: 92.5dB
CDT proudly introduces the automotive Audiophile to the CDT accent system that provides unique control over extra speakers without necessary additional amplification. This system is designed to add front dashboard oriented typically centrally mounted accent tweeters or midrange drivers as well as rear speakers.
The LP-1 variable attenuator can be placed locally within reach for instant adjustment. The attenuator works synergistically with the CS-256 selectable filter to drive tweeters, midrange or full-range drivers .
Click image to download the Introduction to the CDT Accent Control System PDF
CS-HD3 Accent Control Systemflyer PDF
CDT stage enhancement technology proudly announces CenterStage
In the world of high-end audio the terms imaging and staging refer to the complex sonic interaction of two or more speakers to produce a quality of spatial illusion in the sound field.
This means sound sources are heard to be in a certain place and perspective as perceived realistically.
In the AutoSound world this imaging is rarely achieved in any precisely consistent way. CenterStage? joins the Upstage? Stagefront? system to raise the automotive listening experience to new highs.
DT Upstage Stagefront first lifted the stereo image in the direction of the road ahead.
With the introduction of HD-2/CS CenterStage, the off-center perspective in a car is transformed.
This provides each person with his or her own stereo system in the critical forward direction.
Stagefront, UpStage and CenterStage Systems may be used individually or combined synergistically to provide the ultimate personalized listening experience.
HD-2/CS CenterStage provides each person with his or her own stereo system in the critical forward direction.
The HD-2/CS CenterStage 2 mid-Tweeters are driven with an image-correcting signal at a reduced level with a blending module that interfaces directly with the power amplifier.
Working in conjunction with the existing right and left mounted mid-Tweeters - ultimately including extra CDT Upstage mid-Tweeters - driver and passenger are each provided personally centered staging and imaging.
What does it take to make this happen
The CenterStage? mid-Tweeters are mounted in the center of the dash in close proximity to each other.
The centrally mounted pair provides a right and left Tweeter for each person.
These CDT supplied CenterStage? mid-Tweeters are selected to operate optimally in this Image-enhancing system.
Special miniature chambered mid-Tweeters with frequency extension into the middle frequency range transform the image more completely than simple Tweeters could.
The blending module employs a level control and with a provided mounting system optimizes installation and setup in any vehicle.
CDT proudly introduces the automotive Audiophile to the CDT accent system that provides unique control over extra speakers withoutnecessary additional amplification. This system is designed to add front dashboard oriented typically centrally mounted accent tweeters ormidrange drivers as well as rear speakers.
The LP-1 variable attenuator can be placed locally within reach for instant adjustment. The attenuator works synergistically with the CS-256selectable filter to drive tweeters, midrange or full-range drivers.
Operation
The LP-1 is self-explanatory -rotate the knob clockwise to add the desired accent to the system sound. The CS-256 has two switches one with
two-positions for attenuation labeled Level and another with three positions labeled Crossover for crossover frequency.
The appropriate choice is user determined for the circumstances. The Level switch on the CS-256 should be set to Hi if the LP-1 is fully
clockwise and still more sound is desired, otherwise the Lo position is preferred since the amplifier load and to some extent the crossover
frequency will be lowered.
The Crossover should be set to Hi for the hottest tweeter operation along with the Level to Hi and the LP-1 used to get the additional
attenuation since this gives the highest crossover frequency. In certain cases where the tweeter will handle the desired power, the Med and the
Lo level setting (LP-1 turned up) crossover setting may also be used.
Similarly Lo or Med can be used for a typically front mounted midrange with your choice of Level setting.
A rear speaker setup is usually set to Crossover Lo with the Level that works best. As a guide for reference the crossover frequencies are
achieved in a gradual first order manner centered at the following typical frequencies and attenuations:
Crossover Level Frequency Attenuation
Hi Hi 800Hz -7dB
Med Hi 400Hz -7dB
Lo Hi 150Hz -7dB
Hi Lo 500Hz -11dB
Med Lo 250Hz -11dB
Lo Lo 100Hz -11dB
Front/Rear Accent System
Lspk-
Lspk+ Rspk-Rspk+
Lamp-
Ramp+
Lamp+
Ramp-
The frequencies are somewhat higher for theHi Level and lower for the Lo Level, which are
interactive to a degree.
The levels are thus reduced approximately 7dBor 11dB prior to additional attenuation by theLP-1. Both units offer stereo operation andsupport balance control operation.
Installation
The diagram shows the system wired to anamplifier. The same outputs may also beconnected to drive the main speakers since theCS-256
additional load of 10 to 15 Ohms will not
significantly increase amplifier loading. All BNIB
Price: $300 shipped conus. Other fees buyer is responsible
Shipping and Miscellaneous Item Information: On me
Item Pictures: 97.photobucket.com/albums/ag29/oldcadguy/stereo/DSC_0149_zpskkdbbwmn.jpg[/img][/url]
Brand new as in A stock. HD-1 setup bought from shop that is represented on here the name eludes me right now. The CS-256 straight from CDT
The tweets/mids are throwing me off as being the HD-1 series as they look like the housings of the series such as the CS- 020x series why Im asking..X over is hard to tell in the pic
I am asking due to possibly buying here..Not being an azz but know of B stock that can be had for less, though it would be nice to have a stock and with some type of warranty if it still remains/and untouched
A stock, don't think it was ever offered B stock. What cant you see in the x over pic? There are other pics of the xover on the CDT site. PM me your # and I can text other pics if you would like. Pic of box gives description, not sure what the confusion is, unless CDT miss marked it idk. I haven't taken the pods apart. The tweeter do look a lot like the set of ES-010 WD tweeters I have from the outside. I just remembered, screen name of the guy I got the speakers from is Trumpet. I got them from his store.
They do look like the ES-010 tweets..The HD-1 series A..were Aluminum. tweets but I havent seen these in HD-1 series other than Soft Dome tweets, unless you can find out if they are the HD-100series that were pieced together??In conjunction with that Xover
Ill look more into it, but sure do not look like the Hd series tweets though..Sorry, I dont give my phone number .Im ok with speaking through here
I guess you can actually put whatever tweet youwant in that housing to be honest..even the DRT-25 tweets in which I have but if these are the HD -1/100 series,it may be worth my while
Not sure what you're asking. I bought them from Trumpets store as posted above and bought the 256 x-over from CDT. Not sure what else to tell you that I haven't already. The pods have CDT embossed in them, were built at CDT, they say they are HD-1 tweeters in the pods is all I know as I am not going to try to take them apart no reason to. Any more info maybe pm Trumpet since he is who I got them from and I would assume he got them from CDT since that's a product line his shop carries. I don't have any other info for ya. If ya want a CDT HD-1 pod setup and a CS-256 x-over here it is.
Alright .. well thanks man for the info..I may get a hold of Trump and ask..I just thought that you would pop those tweets out real quick and post it up of the series on the back of the mag, as it takes a couple min. I just havent seen any of these pods with HD tweets in them being sold anywhere, other than the HD-1 A series,and those do not look as such.thanks for your time.. Best of luck with the sale
What also helps is the suspensions on them aren’t as tight as a virgin on prom night! Sorry I couldn’t resist using this joke 🤣
33
Holy **** dude went and manually deleted all his post one by one but said he doesn't have time for your ********. :LOL:
307
https://www.cdtaudio.com/cdtnew22/ms.php Real good pricing.
22
wanderer1
wanderer1
Laughlin
wanderer1
    May 31, 2024
    May 24, 2024
