CDA-9883 help
Launchpad
12
TX
Ok so I just got a 9883 like a two weeks ago. Tomorrow ill be installing a mtx rt2100x onto my 6.5 3 way pioneer coaxils arpox 50wrms to each Now my question is which one of these options do I use for the following ?
Bass center frequency - 80hz 100hz 200hz 60hz 80hz ?
Bass Bandwidth - 1 2 3 4?
Treble center frequency - 10khz 12.5khz 15khz 17.5khz 10.0 khz ?
Also should I set the HPF to anything or leave it off?
I did a search on this and didnt really find a direct answer. Thanks
Thats because most of it is for you to decide, a HPF is a great idea for your coax, 80hz should be more than sufficient for those 6.5s. Bass center frequency is up to you, adjust it and see where you like the adjustment best, that is just hte frequency, it doesn't affect the bass until you turn the level up or down. The q(bandwidth) can be adjusted to your liking as well. Same goes for the tweeter.
I love questions like this where we can't really answer it for you //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif.
Launchpad
Launchpad
TX
Launchpad
