CCA wire (copper clad aluminum)
timaishu
San Diego
So I went out a bought 50ft of scosche wire. I never really was able to look at the strands, and I didnt notice till just now that the labeling says its CCA wire.
For my components, I will be using 16guage of this stuff sending 50wRMS x4ohms. Will there be much of a difference? Should I try and return it for copper speaker wire?
So even with my amp bridged at 120wRMS I would be okay?
I realized I lost the receipt so Im stuck with this stuff. I just dont want to wire everything and realize there would be a noticeable difference if I switched to copper. And its thickness seems no different than 16g copper that I have laying around.
CCA is only 66.6% as efficient as pure copper wire, so there is a difference, like the others have said, you shouldn't notice anything with the power your planning on running. The only thing might be whether or not the wire you bought is really 16ga, some of those cheaper companies label ire as one size, but it's really smaller than that. I just picked up a couple rolls of Metra 0/1 ga CCA wire, but it's more like 4Ga wire wrapped in so much insulation that it looks like real 0/1 wire.
Hmmm 66.6%?
Well, Im going to take a look and see if I can find any 50ft rolls of OFC. I never even knew there was much of a difference till I researched it. I dont want this to bother me forever and have to rewire everything.
Gonna see if my friend who works at wally world can return it for me and Ill look for some ofc. Has to be store bought though as the last part for my build arrives the day after tomorrow. And I want to start immediately haha.
Yeah, I guess you right. I would of been better off if I never read the label.
My car should be fairly easy to wire. So I can always re do it down the line fairly easily anyways.
wow people are making a big deal about this
in short runs (usually under 50 feet) CCA is fine
im using it to run my mids and didnt notice a change in voltage or current
If you're using it for speaker wire, it'll get some skin effect anyways (not dc). So I'd be alright with it. With skin effect, the current will be carried on the outside of the strands, hence the coating of the aluminum with copper.
Skin effect on your power wire is less because it is DC, so it's better to use copper, but if you get thick enough CCA, you won't see any difference. The good companies compensate for the fact that they are using CCA by making the wire thicker so that the CCA works as well at carrying the current, but is just thicker and harder to install, but cheaper.
Plus, with speaker wire, you're going to be at a higher voltage (less current) than the power wire you run from your batts.
So.....You'll be just fine.
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
899
fwiw... https://www.pasmag.com/technology/dash-kits-accessories/oxygen-free-copper-ofc-vs-copper-clad-aluminum-cca-cables
At 100 watts and such short runs, you’d have no perceivable difference between 12, 14, or 16 gauge speaker wire, OFC or CCA, nor worry about...
10
440
I’m at 3 yrs on my Tucson alternator. W the electrical challenges i faced it’s been worked hard. Thankfully those challenges have been overcome...
99
9K
timaishu
timaishu
San Diego
seedubs1
SPLBassJunkie
    May 21, 2024
    May 20, 2024
