CCA for a 2200w setup?
Braindead
I'm looking at running a 1600w amp for my sub and a 640w one for my speakers; the monoblock calls for two gauge and the 4 channel calls for 4 gauge. I was thinking of running 1/0 to a dist. block then the 2 gauge and 4 gauge from there. Anyways, would cca work for this setup? Its as high as i think Ill ever want to go, and i really wanna save the money if I can
I would run CCA 0 for your main run and trim it to go into your monoblock, and then for the 4ch a 4ga run from the distro block will be more than sufficient.
When you get into multiple runs, it's usually cheaper just to get OFC to begin with.
I got 2 50' rolls of CCA for $100, which is good up to ~500A.
Even half of that length in decent OFC would be $150+, and only good to ~300A.
Granted, I got my wire on a pre-order. However, if you can find some decent deals, you can really score some savings by using CCA wire.
Braindead
Braindead
York, SC
mylows10
Mike Mccabe
