Cavalier Install, Mag, CDT, eD, US Amps
darren700
got bu/\/\p?
im finally finished the install on my cavalier, the only other thing i might do is make some more trim plates to go behind the amplifiers... any suggestions welcomed!
I use to have a cavalier, with the same door panels. GM made the built-in speaker grills an odd shape, oval similar to 6x9. IMO Id make some sort of backing panel thats mounted via the speaker screws, and expands out from there to cover the old grill. Maybe put a logo on it or something.
Otherwise, looks good man. Nice sub choice.
the ed amps are bridged, one for each front channel, so only 1 rca per amp, that rack is not an extra box, it is two boards held up by L shapped brackets made of mdf mounted to the back of the sub box. and to fit a 3.5 cu ft net box in there, i had to cut some sheet metal where the seat folds down, then great stuff, then fiberglass, then carpet. i will fix the doors, i like the idea about making a cover panel with a logo, maybe out of vinyl... and the amp rack is up so high because a hc2400 is below it, so it could not go any lower
darren700
got bu/\/\p?
darren700
Windsor, Ontario, Canada
traksta15
