Cars being destroyed from BASS
Not much from me. Cracked the rear sliding glass on a Toyota pickup with 2 MA Audio 12s. The vibrations finally got to it, but it was pretty loose fitting anyway. Same setup led to the rearview mirror falling off too.
I've had 2 MA Audio 12s, then 2 12" L7s, then 1 15" SI Mag in my Tahoe with no ill effects.
My cutlass I had to replace the back window with this special re-enforced glass which was very thick and never had a good seal anyway........
The old window would wave at you. Was funny as hell at times till it broke........twice!
Was over 150dbs and port was redone as my whole rear deck, so back window was taking some major abuse!
Over 4krms and 4 9500 12's. Miss that car.
well lets see with mine....... upper consol broke rear dome light gone back hatch broke somthing has broke in the driver front door but its sealed with dynamatt so i dont know what it is ... sunroof broke and about 3 panels in the truck have shook loose
my sunroof has stopped working under normal conditions, and will only work when the system is on tilt lol, and i have the same problem with my rear window motor rolling hround in the hatcj
I swtich cars too fast for anything to break //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif One thing I noticed though is if I play anything with bass around 40 HZ or lower I crack my sunroof a bit so it isnt flopping all over the place.
my 2 15in l7s caused my rear view mirror to fall off my dome lite fell off the roof,my 4x4 button in the dash pops out on big bass hits and also my pass rear door the door wont open from the out side it shook the metal arm off the handel
Nope I am good because I know that ONE 10 is fine for bass. People don't understand that you are not just destroying your car but your hearing as well with loud bass and volume.
Ever think that some of us are married and that is just a plus?
If i play mine full tilt with the rear seat out i get alot of sheet metal flex around my rear view mirrors, and the bolts have started to loosen a bit. Broken rear view mirror and its really loose now and makes an annoying *** rattling noise.The material on the roof flexes a bit and turns to powder and gets in my eyes, some type of foam i think. I get alot of tail light and trunk flex but nothing back there has been damaged yet, other than one of my hydraulic trunk lift things rattling off. Its an old car though so its pretty solid. All steel baby //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif However im sure if i ever upgrade to 1.5k like i had planned ill have issues
Cravingbass123
Soda941, FL gulfside reppin
boomzilla
