Would you mind elaborating please. I currently have a 550w Antec TPII and I'm about to overhaul my system. How exactly would I convert my PSU to power a 500w amp (which I could run say two MAW-12's with //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif )?I use an Antec computer power supply and ran my kenwood amp on it just fine. The amp was rated at 300rms. I currently use that same PSU on an older profile amp and run my IDQ with it. More than enough output for me. I also used to run a Kenwood headunit that powered two front speakers off of the same PSU. It worked great and nothing ever headed up or blew up.
Duh....12 volt ac to dc power adaptor.
A plate amp is a good idea if the setup is permanent. I'm way too cheap for that and I'm only running low power stuff. My profile amp is rated at like 100rms so it's no big deal to power it from the PSU. I'm sure you could use your PSU to power your amp but you're not going to get full power from it.Well, it has dual 12v rails (it's made for SLI) rated at 19 amps per rail max. Watts = V * Amps right? Shouldn't that give me (12*19)*2? If so, that's like 450w, not to shabby IMO. Of course, that is assuming I can join the two rails together, which I don't know because this is all new to me.
I understand PC hardware and Car Audio hardware, but I have no clue how to mix them, lol.
EDIT:
Also, how would I connect my power cables to the PSU? Would that require opening it up or doing major modifications? I think it might be better for me to just buy a plate amp =/
You could just snip the wires and plug them in but that is more ghetto than what I said. My PSU is completely normal and usable when I remove the adapters.Yea, that's to rigged for me. I was thinking i'd be able to just snip the wires and plug 'em in. Plate amp definitely sounds like the winner for me.
Thanks for the info though, I may find a use for this one day...
[saves]
