car speakers making static noise. please help!
  • 2
hebrewhammer
maui
so i recently installed two infinity Reference 860w's, a lanzar DCT425 and a billz audio 2.2 farad capacitor in my jeep cherokee. all seemed well at first but then i started noticing a static noise coming from my car speakers both with the car off and on. the two front door speakers and the two rear door speakers. so i went back through the wiring and made sure all the grounds were clean and had a good connection. everytime i did that it seemed to help for like a day the noise would stop. but id park my car at night and in the morning when id start my car back up the static noise was back. i played with the amp a little and when id turn down the master volume on the amp the static would go away. i only seemed to hear it when the bass would hit. i read online for a few simple fixes and tried them. i made sure my rca's werent running along side my power, didnt change anything. i tried sticking a speaker wire on the outer ring of one of the rca's and grounding it to the deck, helped a tiny bit but it was still there. i tried grounding my deck straight to my chassis, didnt do anything. im really stuck hear. does anyone have any advise? thanks!
im pretty sure its static because i hear it when the engine is off too and only when the bass hits! thank you though. i will rep,lace those and see what the outcome is! hopefully not the amp! haha
also check the rca's and speaker wires for a pinch somewhere
Almost all brands operate the same way. Alpine, Pioneer, Kenwood. The technology is based on what sounds it can produce. Basically all brands...
If you feel that the factory speakers in your car produce a dull sound lacking deep bass and clear, crisp highs, and if you don't want to spend a...
Now you want to know how to do this on your own car? On certain cars that allows you to use head units that are high power, you'll be bridging...
hebrewhammer
hebrewhammer
maui
mylows10
slater
    May 2, 2024
slater
    May 2, 2024
