I have a sedan with a 12 inch subwoofer in the back with this amp just for giving some bass boost: Pioneer GM-X862. Its specs say 380 watts x 1 (for a single 4 ohm speaker).
It says its max watts is 760w x 1. Says its average current drawn for 1 channel is 10amps for 2 channels and 17 amps for one channel. Its not a powerful amp. Its just good enough to give me a slight bass boost and I just got it cheap for $40.
The car battery is "AutoCraft Gold Battery, Group Size 24, 700 CCA" and I bought it 1 year and 4 months ago. It has 900 good reviews on the Advanced auto website.
When I'm waiting at the laundry mat for clothes to be washed, I listen to music and today is the 2nd time that after about 20 minutes of low to medium volume, I tried started the car and the battery was dead. I had to get a jump. I dont know what the problem is. Is that normal for a situation where a sub-woofer is being used with an amp for around 20 minutes and the car is not running?
Do I need
1. A better battery.
2. A solar trickle charger to keep the battery topped up (6 watts and I can put it under the rear windshield)
3. to not listen to music unless the car is running?
4. An emergency jump start kit that has a portable battery for around $50?
5. Another battery? I dont want the extra weight.
6. Some kind of battery capacity monitoring system?
I think I need to do 3, which is to not listen to music if the car isn't running. Ideally I'd like something which I dont have to worry about maintaining so maybe an emergency battery that is charged by the system and only kicks in when the main battery is dead.
I can make electronic projects so I could try making some kind of system where there's a solar charger and it charges the batteries and the 2nd battery switches when low voltage on the main battery is detected. But that would be a big project for me to get it all done.
Any suggestions as to what I should do?
Do I need
