Sold ^^ Car audio stuff ^^
mvw2
I have two subwoofer boxes, both for 12" subs. One is a 1.5 cu.ft. sealed box. It's made with 3/4" MDF, lots of screws, lots of glue, and a bead of silicon everywhere and uses a cup style spring clip wire connector and is wired for DVC (two sets of + and - wires inside the box). It's uncarpeted. I do have spare carpeting and can carpet it if that is a deciding factor. It would be in a medium gray though. I'm just looking for cost of hardware really, so $20 + sh will grab it.
The second box is a 2.6 cu.ft. ported box tuned to 26Hz. This one is carpeted. Again, it's wired internally for DVC. The wiring just passed through the box and a length of wire to connect to the amp as well as a quick disconnect for easy removal is included. It has lag bolts for tie-downs for the rear cargo area. This box is carpeted in a medium grey felt and again constructed of 3/4" MDF, lots of screws, lots of glue, and a bead of silicon everywhere. This ones a little bigger with more into it, so I'm looking at $40 + sh.
I have a single Adire Extremis woofer, 8ohm version. I had two, but one was damaged in shipment. If you're familiar with this, I shouldn't have to tell you anything. For those that aren't, it's a little monster of a woofer, xbl^2 motor, 12mm one way xmax, quite a little beast. I used a pair in a 2-way setup for a while, but they are better suited for midbass duty alone or as a small subwoofer setup. Now only having one, I don't have a lot of use for it plus I've stepped to a larger midbass woofer. I'm looking for $60 + sh for the one Extremis (8ohm version). They are no longer produced (Adire went out of business) and were originally $99 a piece.
I have a pair of Dayton RS52 2" dome midrange drivers. I bought these at Parts Express for a 3-way setup in my car but decided to step to Vifa's TG9 3.5" woofer instead as a better fit for my application. This is a very well regarded midrange, plenty of reviews/test info on them, useful from about 600Hz on up. These are new-in-box, and I am simply looking to get back what I paid for them, $60 + sh for the pair.
I have a Phoenix Gold Xenon X400.1 amp as well. It does 400w x 1 at 1-4 ohms, has steep 24dB/oct (rare) crossover filters, subsonic filter. The amp is cosmetically and functionally as good as new. It includes the original packaging, literature, and birth sheet. Nothing is missing or broken. I want $120 + sh for it.
Hmm, I think that's it. If I have more, I'l add on.
I'm always welcome to pick-up or a local meet if you live in or around souther Minnesota. I know many of these items are on the larger side, and shipping can be upwards of $35-$45, so pick-up is good.
Because the whole sale thing is kind of slow or better yet, without resolve (interest but no purchase), I tossed everything on my local Craigslist to see if I find any local takers. This will probably be especially helpful for the enclosures because pick up is a whole lot nicer than shipping.
mvw2
mvw2
Rochester, MN
blong131
