Car Amp Install Help
SpunkyXL
Hey,
I'm replacing my 4 channel amplifier to another 4 chan amp, and looks like I need some help doing this. From what I can see, it's pretty simple REPLACING an existing amp, as all the connections will be same to the new one. So, I took out all my RCA Cables, Speaker wires, and Ground, Remote, +12v cables from the Old AMP and now I'm putting them in the new Amp..But, when I try to put the GRND, And Battery cables into the slots in my amp, that shit SPARKLES!!! WTF, Why is it sparkling? This scared the shit outta me..how do I correctly put the GRND, BATTERY, Cables into the slot without sparks? //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
no real need to disconnect the negative battery terminal....it will spark on occasion when you make power connections on an amplifier. It should do it one quick time and that is all if ti continue s then you have a problem. Oherwise dont worry about just keep doing what you are doing
thanks all...I took the Neg Cable out, and now no sparks //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif...but I'm having trouble putting the cables into the slots on the amp..Looks like these cables are very thick, and not all the copper wirings are fitting in flush...when I tighten it, the cables are not 100% in...whats the best approach to putting these cables in?
thanks
its due to the engineering on the INfinity amp with the down facing terminals is most likely the reason your having problems tightening them correctly. and its really a must to disconnect your Neg. terminal of your battery unless you want blown fuses..IMO
wow dre...i didn't expect that out of you.....you should always disconnect the neg when installing electronics in your ride.
i only do it when interfacing with delicate vehicle elctronics or if removing apart of a vehicle that is connected to an airbag. When doing amp installs i dont take them off as the last thing i do is pop the fuse in my power wire after everything is done and installed. Not to mention that testing for wiring is pretty difficult with no ground
SpunkyXL
SpunkyXL
JerZ
Worlddre
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
