A tank of 93 won't do any good. It will more than likely make your gas mileage even worse. The octane ratings measures the gasoline's ability to resist detonation (knocking). In other words, higher octane = needs more compression to pop. If the car isn't pinging or knocking, then there is absolutely no need to run anything other than what you have in it now. On cars that don't provide the compression needed to get a good burn out of premium, you're only going to end up with worse gas mileage.
http://www.quiktrip.com/gasoline/myth.asp
Even QT put it on their website.
http://money.cnn.com/2006/07/19/pf/saving/willis/index.htm
Again on CNN.
http://www.consumerenergycenter.org/transportation/consumer_tips/regular_vs_premium.html
And the CEC, citing the American Petroleum Institute.
Do the RPMs do any skipping around, or do they just stutter along with the car. If the RPMs stutter with the acceleration, it's probably engine problems, if the RPMs jump or sit still, it's probably a ***** problem. Pull your plugs and take a pick of the electrodes and check them against something like this :
http://www.spark-plugs.co.uk/pages/technical/diagnosis.htm
If you have an ohm meter you can test your plug wires, assuming you know the resistance per foot they should be at. Most auto parts stores can test DIS modules, if the car has one. This can fail at specific RPM ranges, without failing completely.
