caps????
they are also called bass blockers. they are basically a passive filter that filters out low frequencies. what deck do you have? are the speakers amped? if you crank the bass up, they will still play bass. you wanna high pass them at about 80-100 hz
Don't ever listen to whomever told you that... They're a fucking idiot
not neccesarily
they arent refering to stiffening capacitors, they were refering to the use that a capacitor is much better suited for. that is a high pass filter.
this will keep the speakers you wire them in line with from attempting to reproduce information to low for them to handle, in this case keeping the 6x9's from playing sub bass frequencies.
i have an alpine CDE-9843 not amped just straight off the deck, thanks
not neccesarily
I hear ya.....
when i adjust the bass frequency doesnt it also adjust it to my amp and subs also?
Depends on your deck. Does your deck have a dedicated sub output, or can you adjust the rear outputs so that they are a non-fading output?
As for your question about caps....you could have just asked in that same thread...I gave you a link to the caps you would need in that thread.
alsoknownaz3680
alsoknownaz3680
Campbell, CA
squeak9798
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
