Caprice will Turn Over, But wont Start
open the carb up and hit the fuel while watching inside it. you should be able to see a few little tiny squarts of fuel go into the carb. thats the easiest way to tell if it's getting fuel.
nope.
correct timing, correct air/fuel ratio as well, but fuel pressure at the rail, and checking spark are a good place to start, after you pull the codes from it.
really.
well shit, in that case you need a properly working ecm, ignition switch, compression, alternator etc etc.
simplify guy. you need air, fuel, and spark. rule #1, check for those three before you start anything.
really.
and also compression. i've always heard it as the basic four air fuel spark and compression if you have all four then your car SHOULD run.
Donks
Donks
CO, Ohio
crunktimes.com
