lol. you are so anti-cap //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif thats ok tho, cuz i am tooOriginally posted by jlaine Most likely, yes - it is shot.
No, just seen enough of them die from reverse voltage to know that under most cases, a good backward shot will destroy it. If the electrolytic gel didn't come out of the plug, it may still SORT of work, but chances are you damaged some of the plates in it.Originally posted by nswartley lol. you are so anti-cap //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif thats ok tho, cuz i am too
Yes he has a point, it may not work as it should but if it didnt leak it will still work somewhat but may not have as much capacity afterwards.Originally posted by jlaine No, just seen enough of them die from reverse voltage to know that under most cases, a good backward shot will destroy it. If the electrolytic gel didn't come out of the plug, it may still SORT of work, but chances are you damaged some of the plates in it.
No Prob. But you might also look and see since it is digital to see if it has three posts on top. Two for the battery hookups and a 3rd for a remote turn on for the digital voltmeter. If it has one then try running a wire from the battery + to the turn on post if it comes on then try it and see if it works. If it does when hooked up right and charged right then who knows it might work.//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif Its worth a try.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gifOriginally posted by Killa sin i ordered from the zeb and they say they exchange no matter what thanks
