- Thread Starter
- #16
Yes im using the factory HU. I have a hi/lo converter maybe i need to tune it. I had this same wiring setup with my last system. A 500/1 and a W6 and i never had cut outs. The Amp is showing a low voltage light so i think its a power issue for sure, but ill check out what you sugested anyway bc no1 has been right so far.i'm assuming that since you didnt list a head unit, that you are running the stock one.
its possible that when you distort the factory stereo that it backs off the signal output to avoid blowing the speakers. depending on the signal setup to your amplifier, it may be backing off the signal so much that the amp doesnt see enough input voltage to stay on.
are you using the signal sensing function?
i am not 100% sure on signal issue though.
