Can you hook up 2 amps into a one Capaictor? & The setting for high pass Crossover?
nofriends46
Okay i have a capaictor to a punch amp pushing my 2 12" subs. I'm gonna get a 4-channel punch amp, so i was wonder if i could run the power wire to the capaictor instead of making the power wire to the battery? Any suggestions?
Also what do i set the cross over for high pass? and gain?
Thanks@
Ok ill just do the two ohm for now .i have really good electrical .ill prolly just go ahead and buy a bass 8 or 12 k for now until i can get a...
Got it , LOC black wire actually needed to be grounded . Every video I watched said said it doesn’t and that’s just to reduce noise but apparently...
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
174
If you have multiple amps you do not need to run a power wire from each amp to battery.. You can have a single run of wire with a distribution...
Ill be wiring my next one up at the amps battery bank area and run it to the dash to keep an eye on it
nofriends46
nofriends46
Hawaii, Kauai
chris229
    May 19, 2024
    May 19, 2024
