Can you help me....fast.
beatboxlb
Hey,
I'm trying to get my amp installed and i have a few questions. How do i connect my amp remote wire to my head unit? Which holes do i put my rca's in on my head unit? There is Front Audio Out, Rear Audio Out, and Bus audio Out. The RCA's in my wiring kit are red and black, but the colors on my amp and head unit are red and white. Should i put the black rca into the white hole? Whats the name of that really helpful website with every car audio term defined? Its got a wierd name.
Thanks for all your help,
kyle
Hey,I'm trying to get my amp installed and i have a few questions. How do i connect my amp remote wire to my head unit?
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif What do you mean "how"......do you mean connection wise, cause I always use male/female spade connectors.
Depends on what you are hooking up. If it's an internal speaker amp, hook it up to the front. If it's for a sub, then you could use either (only if you used the rear output, then the fader would act sort of like a sub level controller).
The RCA's in my wiring kit are red and black, but the colors on my amp and head unit are red and white.Should i put the black rca into the white hole?
Colors don't matter as long as you do it the same at both ends. If you put red to red and white to black at the HU, do it the same at the amp
Probably that one supa linked
Thanks for all your help,kyle
That's why we're here //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
not to be rude or anything but you need to find someone who knows how to do this or pay to have it installed ebcause it could cost you more money in mistakes than it would just to have it wired up right in the first place
beatboxlb
beatboxlb
San Jose, CA
rx7vert
