MikeCole89
can you help tell me if this sounds ok? box for two dc level 5s specs at bottom..this is the biggest dimensons i can go to fit it in my trunk
W:34 H:13 D:24=4.94 cubes..recommended for spl is 5.5
(port) H:11.75 W:3.25=38
Will i see a big differnce from 4.94 cubes instead of 5.5?? Also i am not sure what the internal volume would be after sub displacment
12"
Mounting Depth 8.25
Mounting Hole Diameter 11"
Motor Width 9.84"
Weight 78lbs
VC Diameter 3" Flat 8 layer
Magnet Weight 73lbs
Power Handling RMS/Peak 2000/4000 20,000 burst
Impedance D 1 or 2ohm
Sd 494.00 cm²
Suggested Ported 1.75³ ft
Suggested SPL Ported 2.75³ ft
12"
Mounting Depth 8.25
Motor Width 9.84"
Weight 78lbs
Magnet Weight 73lbs
Sd 494.00 cm²
