Can wire my truck system to a 110 generator?
JAMIELILY
I am currently looking to set up my suv sound system (Subs and possible 6X10 for highs) to run off a 110 generator... question is it possible to do? and what will i need to make it possible.
I want to run my 4 channel amp off the generator to feed they system.
do i need a different amp than what i already have in the truck being powered by the battery?
do i need some type of power convertor to bring down amps to 12V? if so what do i need..
I do alot of tailgating.. and instead of caring a whole sound system.. I would like to keep in the truck and fire it from the back area of my tahoe.
No you can do it I just don't really kno how because a lot of audio shops have sound rooms with Amps radios and speakers and there shops don't run off 12 v it runs off 115v - 120v ????
you can get a large power supply for a hundred bucks or more. you would have to transfer the power and ground wires to the power supply. each time, risking damage to everything.
or you can get a used receiver for $30 used that will do a better job and uses 110. just add some connectors to make the speaker wire switch-over easy.
i use a receiver to power a pair of 4 ohm 12's and a pair of 4 ohm coaxials in my garage. i run a passive crossover to split the signal. it rocks, has plenty of bass, and is better than any car amp + power supply i would want to cobble together.
JAMIELILY
JAMIELILY
Texas
keep_hope_alive
