Can u run one 12 in 2 12 box and remove blown one?
Ah I wouldn't if I were you but if it's something your determined to do leave the blown one in or plug that hole... And reduce power... If you can aim for half what the subs rated for to help prevent from bottoming your sub due to the fact your enclosure will be close to twice as large as it should be and more likely have way to much port area unless it's a prefab but you'll still want to wire up ohms
Has one big port hole in center of 2 subs, wana say 5 inches. Each sub has their own little chamber that meets in back of box. I need to grab plans off other computer it would be so much easier than explaining
Just for examples sake regarding electrical, I have 1400 watts total between both my amps and my system has no trouble running everything max...
27
You should run all exact matching subwoofers in one singular enclosure and 1 amp or matching amps for the best listening experience for the space...
I am out of the car audio world the more my ears age. However, I am very much still a hobbyist in the electrical field. With much of my current...
15
Running wattage below RMS won't hurt anything. What the speakers get is the same thing as running an amp with higher wattage and then turning the...
14
nate1017
nate1017
DeFuniak Springs Fl
Jeffdachef
    Apr 28, 2024
    Apr 28, 2024
