can this amp.....
keaton810
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=14539
can this amp be connected to another of the same amp
i bought this one and want to order another soon, what all would i have to do to have one amp powering my pioneer premiers and the other powering my second pioneer. oh and these are the specs
2-Ohm Mono Stable
Variable Crossover (40-240Hz)
Selectable Bass Boost with Wired Bass Remote
Speaker Level Inputs
Peak Music Power: 800 Watts
Load Impedance Capability: 2~8 Ohm
Continuous Power (4 ohm): 250W x 1
Continuous Power (2 ohm): 360W x 1
Total Harmonic Distortion: 0.008%
Signal-to-Noise Ratio: 100dB
PWM Regulated MOSFET Power Supply
Screw-Type Speaker Terminals
Balanced Isolator Input Circuit
2 Channel RCA Inputs Gold
2 Channel Speaker Level Input
Input Level Control Hi-Volt (200mV ~ 6.5v)
Built-in Crossover Selectable LPF
Bass Level Control 50Hz, 0/6/9/12dB
Dimensions 12" x 2-3/8" x 12-3/4"
wouldnt that be easier than to run more wires to my batteries and my headunit and i would have to pay for an install because i cant get my dash apart its weird
keaton810
keaton810
Edmond, OK
keaton810
michigan born
    May 14, 2026
michigan born
    May 14, 2026
