can sealed be louder?
solidcrowd
So i was looking at ROE's great 12 challenge average spl sealed and average spl ported. My question is, is it possible to have a sealed enclosure hit more dbs than a ported enclosure? (same woofer and watts). Also i was wondering an explination for this.. Fi q 1000w 2.2cu. ported hit 126.83 and the kicker cvx 1.5cu.ft sealed 50w hit 126.43.
^^x2, was the TL a mile away from the Q? I would think an Fi Q off 1000 watts in 2.2cu ported would hit 136-138, a 126? Eh.. sounds bs. I believe your statement about that CVX off 50w.
50W should read "750W", he left that part out //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
And those numbers were not instantaneous burps, but averages over the bandwidth...
Around 75% of your sound of your sub is due to how u design & the build quality of your sub enclosure.
Well I can't imagine a seled box being louder than a poted box as long as u r using the same driver & power. Most of the time the ported box is going to be larger than the sealed, remember we r using the same driver.Also the larger box u have the lower the tone of bass you will get. But the bigger box will start to loose out on the crispness that u will get with the smaller sealed, hince the sound quality the sealed box gives u! A Sealed box will give u tight,accurate bass & sealed boxs have a flat frequency response curve.
A ported box will create louder bass than a sealed enclosure, and they allow u to tune the box to a specific frequency to determine how the bass will sound. Higher tuning on a ported box will be louder BUT u will loose sound quality! Lower tuning will still get louder than a sealed box BUT u will have better sound quality than a higher tunned box! Most of the time when using a ported box the "BOOM" is the ultimate goal! So my point is this- if you want loud bass & u don't care all that much about Sound Quality a ported box that is tuned high with a large amount of port area is the way to go to get more SPL! Ya see the tuning of the ported box has a-lot to due with how loud the box is going to be!
solidcrowd
solidcrowd
Buffalo, New York
rlcowboy
