Can I run my tweeters off of the H.U. (without an amp)
8455 has plenty of crossover ability if it has the same amount as the 8454. Yeah sure go for it. Tweeters only need like 15-25 watts to really get going anyway in a normal setup.
Alright,
So if I just use the passive crossovers from the component set, I should be able to get enough clean power out of my H.U. and have no problems... no serious problems that is?
If you use the correct crossover point you'll be alright. Power may not be as clear as you would like since it's from the h/u and they generally have a higher THD rating than an amplifier, but I think you'll be fine.
Of course, more power = clarity at higher volumes.
cad_3326
cad_3326
Nashville, TN
bikinpunk
