Can i install one subwoofer into 4 channel amp ?
Yaris
10
New York
Hi guys,
I have alpine SWS-12D4, 1500 watt max power 500 watt rms
can i install this subwoofer to 4 channel amp ?
i mean how can i install one subwoofer to 4 channel amp so that i take the full amp power !!
i'll use either kenwood KAC-7405 amp or Kenwood KAC-8405 amp
both 720 watt max power with :
4 x 60W at 4ohms (0.08% THD) rated power output
4 x 90W at 2ohm (0.8% THD) rated power output
2 x 180W at 4ohms (0.8% THD) bridged rated power output
You could bridge the amp to 2 channels and run one channel per voice coil but unless you are extremely accurate with gain matching, you'll end up with poor sounding bass at best and at worst, burnt coils and/or amplifier.
I would consider finding a decent monoblock amp for your sub. Also, peak power is an irrelevant number.
Pull the head unit out, and at the harness use a test light to check 12v, ground, and Accessory. If all three are good, you have probably...
That blue wire with the "remote control" sticker on it: It's NOT a remote control wire. Its a remote... control wire. Its a switch that...
problem was the LOC burnt out when I had touched cables. got a new LOC and now all is working. have to get the gain right, lights flickering with...
Storage is actually pretty big ( but not big enough for an enclosure that's mounted on the door because it closes in an angle believe it or not...
15
Yaris
Yaris
New York
bbeljefe
