Can i fix my HiFonics?
Ctminime
1/2 Team SubHertz
ok today my Hifonics died..... to see what happend to burn up i took the plate off and and i see this little black dealer off the side of the board and if i can find out what it is and get another one im sure (that with my previous skills soldering) that i can fix it.... i just need to know what part im looking for.... and it this thot of me fixing it just false hope.... heres a pic to maybe help figure it out....
http://i39.photobucket.com/albums/e156/ctminime/101_0926.jpg
There's a lot more to it than that. There should be a spec printed on the FET in either white or grey. The things that matter, among others, are on resistance, threshold voltage and current capacity. You need to replace with the same spec.
I would suggest taking the whole shebang into an electronic supply store and see if they can help you out.
gate capacitance is also a pretty big player.
Its possible that they removed the part number from the fets.
The part number would be located same place as the IR is in that picture.
I just took another look at your pic. it looks like a resistor burned up as well.
you cant really tell what it is since it is all burned up. But the marking on the PCB almost definitly looks like an R to me (R25P).
I think I remeber reading somewhere that all of the mosfets should be replaced because they might be slightly damaged as well.
Ctminime
1/2 Team SubHertz
Ctminime
Lincoln, Nebraska
djman37
