can i fit a 6.0 cubic feet box for my 15'' l7.........
They have pretty big trunks, I dont see why you should be able to.. My question is why are you choosing such a large enclosure for them. 4-4.5 seems to work perfectly for them.
because its not such a strain on my electrical system:crap:
What does box size have to do with strain on your electrical system? If you were worried about strain on your electrical system, you wouldnt have went with the xenon 1200.1, as it is a power hog:)
What does box size have to do with strain on your electrical system. If you were worried about strain on your electrical system, you wouldnt have went with the xenon 1200.1, as it is a power hog:)
i was told that the box size estimates how much power is needed to produce spl and if you have a small box then i wont get as deep and hard hitting bass as i would with a bigger box
Box size doenst always determine spl. Many times smaller boxes are optimal for producing spl. The l7s do well in 4.5 cubes, and will go low. Not saying they wont do okay in 6 cubes, but they will be a bit more sloppy in such a large box. As I mentioned before current draw wont have anything to do with the box. If your concerned about current draw, then ide suggest you get a tantrum instead of a xenon. Much more efficent, and more powerful.
this is really tru?
doesnt big boxes goes freakin loud in the low end and hits hard in there also(20-50hz) and then have less output and less hard hitting in the high end(60-90hz)?
small boxes do the contrary?
okay how much do tantrums usually cost?
Check on ebay, they are usually around 300. They would definately take stress of your electrical system. Or you may want to check out some other amps more suited for your needs. xenon is a great amp with all do respect, but they are built with sq in mind, so they arent very efficient at all.
MY XENON WORKED WELl WITH MY OTHER L7 WHICH BLEW DUE TO INCORRECT INSTALLATION.//content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
They are very good amps, just not efficient. If you keep it, just make sure you have the proper size wiring, and any other upgrades. I would suggest 0 guage for it, and be sure to use both power terminals for best results.
bcleachd
Banned
bcleachd
columbus ohio
iamamp3pimp
